Picked up a 1998 S70 T5 to restore...
Old Apr 16, 2014 | 10:35 PM
Default Picked up a 1998 S70 T5 to restore...
Hey guys and gals, I picked up this nice S70 T5 with 106,000 miles and a burnt valve. I'll be fixing it up, taking it as close to stage 0 as I can, then turning it over to someone that wants a nice car to drive 4+ years.
Old Apr 16, 2014 | 10:37 PM
Here is the YouTube progress play list:
Volvo S70 T5 Restoration - YouTube
I'm going a bit overboard. Does anyone know how to time the NA cams on the stock ECU?
Old Apr 17, 2014 | 08:18 AM
pkrface's Avatar
Good luck! Just out of curiosity, what did you pay for it?
Old Apr 17, 2014 | 08:22 AM
I got it real cheap because of the bad motor.
Old Apr 17, 2014 | 09:05 AM
Actually, I probably paid to much for it.
Clean retail with the low mileage is $5,100
A retail head job w/valve on a modest side is $2,800
Fuel injector service $ 75
Timing belt parts and an extra hour is $ 450
PCV Parts with another hour labor is $ 250
The dent repair in the door is likely $ 700
Brakes and rotors retail would cost about $ 550
Coolant flush would cost $ 75
Transmission service $ 150
CV Axle boot replacement $ 145
Antenna mast replacement $ 125
Odds and ends $ 100
TOTAL COST TO RESTORE would cost about: $5,420
If I add in what I paid, I'm would be upside down. Doing the work myself will save a ton but as for paying anything for it, salvage cost is all it was worth.
Old Apr 19, 2014 | 05:12 AM
Ok, so I was told that the NA cams need to be timed 4° apart. The intake -2° (retard - counter clockwise - top towards the back of the car) and the exhaust +2° (advance - clockwise when looking from the front of the motor - top towards the front of the car). I'm going to time it with the head out and secure the cam sprockets on the cams.
Old Apr 19, 2014 | 05:44 PM
mikeles's Avatar
Like that color...
...m
Old Apr 19, 2014 | 09:30 PM
gdog's Avatar
You'll need one of these:
Cam Timing Tool
Where you set the timing will depend on what other mods you're doing, to some extent..
From here (context is w/ard tune):
Cam timing and wastegate setting recommendations:
15G -1 intake, -1 exhaust, 3.3 psi
16T -2 intake, -2 exhaust, 3.5 psi
18T -2 intake, -3 exhaust, 3.7 psi
19T -3 intake, -3 exhaust, 3.7 psi
20T -4 intake, -4 exhaust, 4.0 psi
20G -4 intake, -5 exhaust, 4.4 psi
*NOTE: For vehicle with non turbo intake camshaft installed, set the intake camshaft at an additional -4 degrees.
Old Apr 28, 2014 | 09:12 AM
Thanks for the details.
She's back on the road.
Old Jul 14, 2014 | 06:17 PM
98S70fromTX's Avatar
Robert,
I just got finished watching your Youtube videos on this project. I really enjoyed them. You did all that with the car IN THE STREET and made it look easy. Holy moly. You should be doing depot level maintenance on B-2 bombers, on the flight line.
That is a really nice car, especially after the engine work and interior cleaning that you did. Why do you think it will last only another 4-5 years?
Impressive work.
-Paul
dondogs
Jul 15, 2010 04:07 AM
schwalbe181
Jun 28, 2010 03:33 PM
mkimse2000
Jun 11, 2010 11:08 AM
Brad Geezy
Sep 29, 2009 01:05 AM
tbrads
Jan 4, 2006 11:04 PM
