power windows not working
Old Sep 8, 2006 | 03:19 PM
bartsvolvo's Avatar
Default power windows not working
Hey guys im new to the forum actually to the Volvo scene in general. I just picked up a 1998 S70 a couple days ago. The problem goes like this my brother was driving it around taking care of some stuff. He went to roll up the windows and he said that the master switch smoked a little when the windows rolled up. He got the windows up about half way and thats about it. He also said that the sunroof isnt working. Now the other thing is my sister accidently pressed the window switch again and it worked for second and then nothing. None of the windows work or the sunroof. Can someone please shed some light on this problem. Thanx
Old Sep 9, 2006 | 12:09 PM
Default RE: power windows not working
Master switch is bad. It might have also blown the fuse.
Old Sep 9, 2006 | 12:43 PM
bartsvolvo's Avatar
Thanx. Is there any other fuse box besides the two in the engine bay. And are the power windows listed by themsleve or in junction with something else.
Old Sep 9, 2006 | 01:30 PM
Those are the only 2 fuse boxes.
Not sure just look under the lid and see what is listed.
Old Sep 13, 2006 | 05:47 AM
sandders08's Avatar
First check if all the relays and fuses are okay. The motor is unlikely to be burned out or blown. You might need an allen wrench for this if you're confident enough that you can fix it yourself.
mjohnny
Mar 18, 2013 02:35 PM
sbellm
Feb 17, 2011 09:37 AM
Musicjunkie2k
May 27, 2010 12:19 PM
dennisp55
May 21, 2007 11:51 PM
delta410
Apr 3, 2006 09:04 PM
