Radio fuse blows instantly?
Old Sep 2, 2011 | 03:18 PM
jbrown16's Avatar
Default Radio fuse blows instantly?
We had to get a jump start today. Everything came right back on like it should, except for the radio. Not the code thing - I mean no power to the radio at all. So I replaced fuses 7 and 32, thinking that may do the trick. I'm realizing now that for fuse 7, right when I insert the new fuse, it sparks a little and blows it right away. I could do it a hundred times and each time the inserted fuse would blow on contact with the port.
What is going on here?
Thanks in advance!
Old Sep 5, 2011 | 07:53 AM
There must be a short somewhere. Does it happen with the car off and the key out of the ignition?
What kind of car do you have, year, model, etc.
I always try to warn people about jumping cars but no one seems to believe me.
Old Sep 6, 2011 | 06:39 AM
jbrown16's Avatar
It does happen with the car off and no key in the ignition. It's a 1999 s70 non-turbo, still going strong at 171k miles. All other electrics seem fine except for this radio issue.
Old Sep 6, 2011 | 09:13 AM
There has to be a serious short somewhere. Strange that it would blow with the car off and key out. Does the security system still work? You can test it by lowering the window, locking the door, leaving it alone for 10 minutes, then reaching in and opening the door.
Old Sep 7, 2011 | 11:12 AM
jbrown16's Avatar
Yes, the alarm function still works. Just made every dog in my neighborhood start barking when I tested it :-)
Old Jul 18, 2015 | 02:19 PM
Volvo Manic's Avatar
Exact same thing here. Even with the radio disconnected I get an instant blown fuse on #7 15 Amp fuse. Everything off and key out of the ignition. Well the door was open and car had run in the last 30 minutes so not totally powered down, but the ACC items were.
Any ideas from the forum?
Old Jul 18, 2015 | 04:17 PM
go to volvowiringdiagrams.com and download the PDF. You should be able to trace the radio lead back to the fuse to see where there are junctions. You should be able to work with an ohm meter to see where its shorted to ground (ie between the fuse and the radio )
j_c_c
Apr 30, 2011 01:54 PM
fastoldcarz
Aug 9, 2010 06:19 PM
mischief4l
Sep 2, 2008 07:13 PM
chapin
May 28, 2007 11:18 PM
mbauer
Feb 11, 2007 07:07 PM
