Fuse blows with no H.I.D Kit, up the Fuse???
Old Aug 29, 2008 | 02:19 PM
mischief4l's Avatar
Default Fuse blows with no H.I.D Kit, up the Fuse???
I jsut had a World Imports 8000K H.I.D. kit installed. Good kit, no error messages, but the low beam fuse in the engine compartment keeps blowing after about 15 minutes of use.By default, its a 15 Amp fuse. I know the kits is supposed to draw the same power, so I shouldnt have the fuse. I was thinking about changing the fuse to 20 Amps. There are some more fuses in the car for low beam (10 Amps each light), but I dont think I will touch those.
What do you guys think?
Old Aug 29, 2008 | 03:08 PM
SkyWriter's Avatar
Default RE: Fuse blows with no H.I.D Kit, up the Fuse???
i would not up the fuse. how many watts is the kit rated at?
i have 55watt HID kit and it's supposed to be less power. blowing 15amp fuses sounds wrong. is it both L&R fuses or only one side?
Old Aug 29, 2008 | 06:53 PM
ORIGINAL: SkyWriter
+1
Old Aug 30, 2008 | 04:57 PM
mischief4l's Avatar
Well the one that blows is the one in the engine compartment. Thats for both low beams and it is rated at 15 Amps. Then it breaks down to two seperate fuses by the driver door fuse box, one for left, one for right.
Its a regular 35W low beam H7 kit
Old Aug 30, 2008 | 05:37 PM
All the wiring hooked up correctly?
Old Sep 2, 2008 | 06:11 PM
mischief4l's Avatar
As far as I can see yes, I even put black tape around any exposed contacts between wires in case of electrical short
Old Sep 2, 2008 | 07:13 PM
How were they connected by the headlights?
Maybe unplug one and see if the fues blows to try to figure out which side may be doing it or if both are unplugged then it may be before the lights.
fastoldcarz
Aug 9, 2010 06:19 PM
kupiec79
Oct 19, 2007 12:54 AM
Rogue
Jun 11, 2007 02:15 PM
chapin
May 28, 2007 11:18 PM
mbauer
Feb 11, 2007 07:07 PM
