Rear door unable to open
Old Feb 18, 2009 | 04:54 AM
carpcatcher's Avatar
Question Rear door unable to open
Hi, My S70 passenger side rear door is unopenable. The lock button pops up and down with the central locking, but either from in/outside you are unable to open the door. Its like a rod or something is disconnected inside the door panel. Can I access the door panel with the door shut. Thanks
Old Feb 18, 2009 | 07:00 PM
Sorry to say but that is usually a bad door lock assembly. There is plastic parts that break internally. Usually the door panel gets trashed as well.
Old Feb 19, 2009 | 03:42 AM
So its a matter of:-
-Obtain new/used trim panel
-Trash current panel to gain access
-Fix problem and trim......
Ok, of to the scrappies for bits then
Thanks for your help.
Old Feb 19, 2009 | 06:51 PM
You will have to replace the lock once you get in there.
I have been able to get a few off without trashing them good luck.
frank weiler
Oct 11, 2012 06:33 AM
AWSIN
Mar 11, 2010 06:00 PM
AWSIN
Mar 9, 2010 08:47 AM
msbizz
Apr 4, 2008 12:55 PM
msbizz
Mid West
Apr 3, 2008 05:19 PM
