replacing a used engine
Old Dec 12, 2012 | 12:30 PM
ampelia's Avatar
Default replacing a used engine
working on a 2000 s70 i replace the engine with a used engine because the original one over head it and it when bad the car starts and idles fine but when you depress the gas pedal it will not ecelerate it just idles any ideas what cause it be
Old Dec 12, 2012 | 12:35 PM
Hi and welcome to the forum. Is the throttle plat connected to it's linkage?
Old Dec 12, 2012 | 02:05 PM
ES6T's Avatar
Information removed.
Old Dec 12, 2012 | 08:31 PM
Ozark Lee's Avatar
I think I can decipher that post well enough to respond with at least a couple of questions.
When you changed the engine to you use the old Electronic Throttle Module, the one from your old engine, or did you install an ETM that came with the replacement engine?
The ETM is "married" to the car via a software download and using an ETM that was not originally programmed to the car will not work properly.
Secondly, are you sure you plugged the pigtail from the ETM back into the appropriate connector? It has a tendency to hide behind the starter wires.
...Lee
Old Dec 13, 2012 | 10:10 AM
ampelia's Avatar
Originally Posted by ES6T
Did you swap the throttle from the old engine to the new one?
no i used the one that came with the used engine
Old Dec 13, 2012 | 10:13 AM
ampelia's Avatar
...Lee
no i used the one that came with the engine and im think i plugged in the pigtail right
Old Dec 13, 2012 | 04:11 PM
Ozark Lee's Avatar
If you still have your original ETM install that one instead of the one that you got with your replacement engine. The original throttle module will already be programmed for your car.
...Lee
heimelw
Mar 23, 2009 07:58 PM
healthteacher
Jun 20, 2008 07:04 AM
joseangel
Jun 18, 2008 07:18 AM
mvmidtown
Jun 4, 2008 05:34 PM
stevo77
Jan 28, 2008 08:28 PM
