S70 Manual Transmission shifting
I just acquired a 1998 S70 with manual transmission. The car is really clean and appears to be in good mechanical shape. It has 205k km (120k miles). I find shifting gears to be rough. It shifts easily into 1st and 5th gears, but 2nd, 3rd and 4th gears do not shift smoothly at all. Double clutching does not help much at all. It's difficult to get the lever into gear. My wife's Mazda5 (a car I consider cheap) shifts real smooth, and has more "guts", which is strange considering that the two engines are similar in size and output. And I think the mazda weighs more too. I previously had a 2000 VW Jetta, and it's gear box was silky smooth too. So what's the deal? Is there a simple fix to this?
How do I verify these bushings? I'm not very sure what I'm looking for. I'm pretty green in DIY mechanics, although I'm keen to learn. Is it something like this? http://www.volvoforums.org.uk/showthread.php?t=80433
Thanks for the pic. Do you mean then that I only need two bushings (or bearings), and that these cables are somewhere under the air box? I imagine that in order to giving the shifting back its smoothness, there need be very little play inside the bushing. I suppose if I could get the inner and outer diameters of these bushings (spec) that I could go to any place that sells bearings and get replacements. Is this a job a could do just by raising the car on jack stands?
I replaced the two bushings with bearings (skateboard type); one bushing was torn, the other looked ok. However, the improvement in shifting is almost negligible. Shifts to 2nd seem a little better, but 3rd and 4th seem the same - still notchy. Any other linkage bushings to consider? Any other ideas?
