S70 oil pan question
Old Oct 12, 2010 | 07:48 PM
jtweb1218's Avatar
Default S70 oil pan question
Does any one know if the '98 oil pan is compatible with the '00 s70? Or is there a way to fix a small srape/crack on one? (wife hit a big rock......) it's a small leak but annoying and costly.. I was thinking JBWeld at first but I don't think that it would hold to the pan...
Any Ideas??
Old Oct 12, 2010 | 09:19 PM
No the newer ones will not work. BUT the 94 850 through 98 oil pan should work.
Old Oct 12, 2010 | 09:52 PM
Would it matter the engine? 2.3 vs 2.4 vs 2.5?
Old Oct 12, 2010 | 09:53 PM
That should not matter. Even Turbo or non should not matter.
Old Oct 13, 2010 | 07:34 AM
jtweb1218's Avatar
so just to clarify the '98 oil pan will fit the 'oo volvo??
Old Oct 15, 2010 | 09:48 PM
Carrots's Avatar
No, the 98 pan won't fit a 00 model, or vice versa, because of the oil filter housing and oil cooler. You can, however, use any 99 and newer pan, including 2.4, 2.3, and 2.5 engine pans, from 60 and 70 series cars. turbo, non- turbo, etc. don't matter
Oh, and make sure to replace the oil pan o- rings while it's off- these are prone to cracking. And use the "real" Volvo gasket sealer. It's expensive stuff- $30/ tube, but it's well worth it, as it's the only stuff that reliably works. Use a small trim roller to apply it.
mcgiiver
Jun 9, 2012 07:00 AM
asavinon
May 13, 2011 11:51 PM
mercb
Dec 11, 2009 01:49 PM
Keith Tobberman
Nov 26, 2007 12:35 PM
