S70 t5 98 p0505 ıdle
Old Feb 9, 2023 | 09:09 AM
s70T5dm's Avatar
Default S70 t5 98 p0505 ıdle
hello my car was giving p0505 idle fault, the revs happen at 1200 1300s, sometimes it goes up to 800 900 revs to normal. I installed a new orginal bosch idle motor, but the fault light is still on. It gives p0505 on the diagnostic device, what could be the problem?
Old Feb 9, 2023 | 05:57 PM
did you use an OBD2 scanner to view and clear the code? If so, you probably have an air leak or bad hose in there. Here's a bigger discussion on this code that may give you some ideas on what to check
https://www.matthewsvolvosite.com/fo...64a79da00f2329
Old Feb 11, 2023 | 09:19 AM
s70T5dm's Avatar
yes, it gives the code p0505 with Obd2 and the fault light is on. I delete it. After driving 10 15 km, it lights up again. I checked the hoses, there seems to be no leakage, but I'm still thinking of doing a smoke test, I hope I can solve it. Thanks, that information was good, I'll replace the throttle gasket.
Old Mar 29, 2023 | 06:50 PM
s70T5dm's Avatar
my problem was solved thanks Pcv valve pipe had a leak. I found the fault with the smoke test.
s70T5dm
Sep 21, 2022 01:16 PM
HickstedS
Mar 15, 2022 07:52 AM
98.volvo.s70.t5
Apr 14, 2015 11:25 AM
VolvoSwag
Sep 7, 2010 11:23 PM
seattlego
Jun 24, 2009 02:23 PM
