S70 tries cranking when the key is out
Old May 31, 2008 | 10:08 PM
m2point1's Avatar
Default S70 tries cranking when the key is out
Old Jun 1, 2008 | 07:33 AM
Default RE: S70 tries cranking when the key is out
Recheck all electrical connections.
Sounds like a bad ground or shorted wire somewhere.
Old Jun 1, 2008 | 11:54 AM
jsj_297's Avatar
Yeah, could also be a sticky starter relay. Did you disconnect neg battery cable durring your car maintenence? I hope something didn't damage ECM. That or a bad ignition switch, is also a possiblity. You could try pulling ignition fuse, see if it still tries to start, that might help isolate your problem.
dman777
Dec 19, 2011 11:31 AM
dman777
Apr 5, 2011 12:38 AM
Jonathan Logan
Aug 18, 2008 05:54 AM
gloria13
Apr 21, 2008 12:29 PM
sdat1333
Feb 10, 2007 07:52 PM
