S70 Windows Not Working
I have done some searching, even on the 840 forums, but cannot seem to get a clear answer.
The windows in my 200 S70 will not work, along with the sunroof. The door lock/unlock is not working either. Obviously there is nto a fuse for the windows or a relay I can identify. Before I go tearing the door apart does anyone have any experience fixing this issue?
Thank You
Thank You
Another thing you might check, though I don't know if it's related or not...
On mine I had to replace both the front window/door switch panels because they would work intermittently and were just plain worn out. Since then I occasionally have issues with the door locks, including the gas filler door latch and the mirrors. Typically what it is, is the door lock/unlock switch on the passenger side is stuck partially engaged and it pretty much disables all other door controls. Switching the switch from locked to unlocked a couple times will clear it up.
Might be worth a shot checking on something like that before replacing your ignition switch.
