s70 wont start
Old Sep 13, 2012 | 08:14 PM
rockjj's Avatar
Default s70 wont start
S70 2.4 non turbo not getting fuel, could it be a bad throttle sensor
Old Sep 14, 2012 | 10:56 AM
gdog's Avatar
Didn't say what MY (model year)?
And by "not getting fuel" do you mean you have no fuel pressure at the rail?
Old Sep 14, 2012 | 07:34 PM
rockjj's Avatar
s70 1999 and i have fuel pressure, it sometimes it has to be started by starting fluid
Old Sep 15, 2012 | 01:31 AM
slimflex2's Avatar
does it crank when you tried starting it?
Old Sep 15, 2012 | 07:15 AM
rockjj's Avatar
yeah it cranks over just wont fire
Old Sep 15, 2012 | 07:20 AM
rockjj's Avatar
Can the throttle position sensor be adjusted
Old Sep 15, 2012 | 09:01 AM
Have you pulled a plug to see if they are getting wet with fuel?
Old Sep 15, 2012 | 09:47 AM
slimflex2's Avatar
you might want to check for fuel pressure first.then next the fuel pump relay.
Old Sep 15, 2012 | 09:25 PM
gdog's Avatar
So do you have fuel pressure (and what is it in psi?) while cranking? The '99 MY and later has much more complicated fuel pressure regulation (return-less) system than the '98 and earlier. Ck this link if you're interested in learning more about it.
Since it runs on starting fluid, that would tell us it's only lacking fuel, meaning if you do have proper fuel pressure, then the injectors are not firing (being activated); have you checked that? And you said "sometimes"; do you possibly have intermittent spark? Have you checked that?
Why do you ask about the throttle position sensor? Another change that was new for '99 MY was to replace the mechanical throttle with the ETM (electronic throttle module, aka drive-by-wire) which is a whole other can of worms, but I don't believe that would cause a no-start.
suze
Jan 30, 2014 07:42 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
waltonsauto
Feb 1, 2012 10:31 AM
waltonsauto
Jan 31, 2012 12:40 PM
furball3
Jan 28, 2007 03:31 AM
