serpintine belt
Old Jan 18, 2009 | 07:33 AM
football coach's Avatar
Default serpintine belt
I am finishing an engine replacement. I put the a/c compessor, altenator, power steering pump and pullys back in the car. When I went to put the belt on, it is four inches to long. I checked it with the old one(same size)and I know I am routing it corectly. I must have make a mistake putting the components together?? They all fit on the engine perfectly so I don't know how I could have made a mistake. I need a step by step maybe with pictures. HELP!!
Old Jan 18, 2009 | 08:22 AM
Default RE: serpintine belt
There is 2 ways to run the belt. I cannot find the pic I had. But the difference is running around the Alt. and idler pulley. One way it goes over the idler then to the alt. The other way it goes over the alt first then around the idler.
Old Jan 18, 2009 | 08:25 AM
Also if it is a 99 or 2000 there is a totally different way it goes.
Old Jan 18, 2009 | 08:58 AM
placer61's Avatar
Go to www.ipdusa.com , click on your model, find the serpentine belt page, and you should find an Installation Tool Kit. There you will find installation instructions (pdf). It will show you the right (and wrong) routing of the belt.
kags1969
Jun 24, 2010 03:24 PM
iscwebe
Feb 9, 2010 12:50 AM
Ahmed
Nov 21, 2009 03:29 PM
reedkm
Sep 22, 2009 07:42 PM
boulwie
Dec 23, 2007 11:41 AM
