SERVICE LIGHT STAYS ON S70
Old Nov 2, 2007 | 10:03 AM
chachouu's Avatar
Banned
Default SERVICE LIGHT STAYS ON S70
I just recently changed my plugs and wires,air filter,and cabin and oill change,eversince then the SERVICE LIGHT stays on for the first minute or so after I start my car.
help please
Old Nov 2, 2007 | 10:28 AM
ocean238's Avatar
Default RE: SERVICE LIGHT STAYS ON S70
what year is you car? the later ones, you can reset it by pressing the trip reset botton 1 sec. after key position II, but you have to press for a length of time.
In Europe if your car is pre 98 you have to have that done at the dealers, there's no way you can reset it without the tools, as far as i know anyway.
hope this helps
Old Nov 2, 2007 | 12:09 PM
chachouu's Avatar
Banned
I am in the US and the year is a 1998 s70 non-turbo
Old Nov 2, 2007 | 01:57 PM
JimKW's Avatar
You need a special ODB-II unit to turn off the Service light. Mine is on, but since it goes out after about 2 minutes it doesn't really bother me.
Old Nov 2, 2007 | 02:16 PM
ocean238's Avatar
yes so you would need a speical tool to reset the light, but really to be honest it doesn't really mean much, as long as you know your car is fine, then it is!
Old Nov 2, 2007 | 04:28 PM
JimKW's Avatar
You turn it off and it will come back on in 5,000 miles. It tells you to take your car to the dealer so they can rip you off for an oil change and turn the light out for you. I had mine in for something else one time and asked them to turn the light out while they had it and the said only if we change the oil. I spent over $200 and they would not reset the light. I have not gone back to them since.
Old Nov 2, 2007 | 07:23 PM
ocean238's Avatar
really? that's so bad, you did the right thing not going back, i got hold of some self run volvo specialist who did it for me when i popped in one day to ask a couple of questions, but i yes you are right, the purpose of that light is so they could rip you off!
Old Nov 5, 2007 | 08:56 AM
chachouu's Avatar
Banned
ok,then I guess I,ll leave it on,until hopefully it,ll go off by itself.
Old Nov 5, 2007 | 12:18 PM
JimKW's Avatar
It won't unless you remove the bulb. Which isn't a bad idea.
Old Nov 7, 2007 | 08:00 PM
dkbmx8485's Avatar
ORIGINAL: ocean238
hope this helps
My 98 s70 turbo is doing the same thing. Is there any other reason this light may come on? Could you tell me more about this? Will it work for mine, or do I need the "special tool"? Thanks.
Old Nov 9, 2007 | 11:24 PM
chachouu's Avatar
Banned
I had my timing belt serviced and the mechanic hooked me up $325.00 all together not bad.
no more service light for me.
repairmantommy
Feb 15, 2009 03:07 PM
hillbilly
Jun 16, 2008 08:36 AM
VESPA14
Apr 16, 2008 06:33 PM
tarheel00
Aug 18, 2007 09:05 AM
jcmartin
Apr 26, 2006 09:31 PM
