spark plugs wires are jumbled
I'm not sure if they have it on Volvo's but there should be a number with 5 digits (1-5) on the engine block right near the distributor somewhere.(this is the firing order) Also, if you can see it, the slots for the spark plugs are numbered, thus, further aiding your dilema :]
Hope this helps.
Hope this helps.
Ok, here's the deal: On all the 5 cylinders and starting from the back of the block, the cylinders are as follows: 1,2,3,4,5. Now the distributor from the back of the block from clockwise and starting from 6 o'clock is: 4,2,1,3,5.. Connect the wires and presto..............
r.
r.
ORIGINAL: samadkins29
well i dunno, the car runs, you know my problems, lol
car does stammer in the lower rpm range at idle
If that doesn't work, clean or change the plugs, it sounds like one or two might be dead or close to it.
my dads truck had a similar problem recently and i took it into my auto teacher, we changed the plugs after trying to diagnose the problem, truck sounds and runs fine now.
[quote]ORIGINAL: Milk Dud
Check your distributor, the car could be set at too low of an idle. the previous owner could have possibly set it too low and not have noticed.
Say, what part of the distributor do I adjust to set the correct idle? Do I need a wrench or a screw driver? I'm not sure that I have any metric screw drivers.................
r.
r.
Every car i've ever timed had a nut so it's probably just that, and as for adjusting it, anywhere you can get a good grip to easily adjust it is fine.
If you don't have a timing light you'll have to go by ear and in that situation just raise the rpm's slowly untill the stammering goes away.
Oh, and make sure you're in neutral. :]
Safety first right? Lol
edit: I almost forgot, to adjust the distributor you just turn it left or right. but slowly.
ORIGINAL: Milk Dud
#18
futbolfan15
04-02-2010 09:56 PM
