Starting issues
Old Jul 3, 2015 | 07:34 AM
RA082324's Avatar
Banned
Default Starting issues
So a brief history and run-down:
About 2 years ago now I got this vehicle. One of the first days I had it, it wouldn't start...no click, no attempt, no lights going dim..nothing. Tapped the starter while trying and it started right up. Ordered a new starter but since it never happened again, never got around to putting it in.
Fast forward to about a week ago...car would have issues starting, you'd hear the starter slip and make massive noise; this would get worse in hotter temperatures. This morning I put the new starter in, started right up (TYC branded starter). I turn it off, try again, nothing, same symptoms. I wait a few seconds and try again, good. Do this all over again, nothing, then good. Then I tried another few times in a row without issue and seemingly (for now) anytime I try it's good. Are there any known issues that can cause this?
I can also tell you yesterday on the old starter it sounded entirely wrong (slipped, etc) but got the car started, then the car ran like crap for a few blocks (very low power, Check Eng light) and once I restarted it, fine.
Hoping this isn't something bad in the works...
Old Jul 3, 2015 | 03:05 PM
RA082324's Avatar
Banned
An update:
I went out there this afternoon and tried to start it, nothing. Took the ground wire off, re-attached, started right up. I used a pair of pliers and tightened the ground wire clamp before re-attaching again, hopefully that was the issue.
burtonsnowbird
Feb 11, 2006 05:02 PM
burtonsnowbird
Feb 7, 2006 01:07 AM
splash114
Jan 29, 2006 10:36 AM
PhilM
Jan 23, 2006 04:21 PM
