Starting problems
Old Mar 19, 2010 | 07:19 PM
Meat's Avatar
Default Starting problems
Hello all. I have a 97 s70, that is not startin for me. So i figured ide see if anyone knew what is wrong. I drove home, stopped, turned off the engine. Came back ten minutes later and it wouldn't start. It turns over for a while, so its not a dead battery i dont think. Any ideas?
Old Mar 19, 2010 | 07:34 PM
You need to check the basic's fuel, spark, injector pulse.
Old Mar 19, 2010 | 07:43 PM
Meat's Avatar
do you know how, or where to find out how to see if it is getting fuel? sorry im rather new at this.
Old Mar 19, 2010 | 08:09 PM
There is a fuel rail under the hood. It is on top of the intake manifold. On the end(drivers side) there is a valve that looks like of like a valve stem for a tire. Remove the plastic cap and push the center in and see if alot of fuel comes out. Also you can hold it pressed in and have someone crank the motor and see if the pressure goes up.
Old Mar 19, 2010 | 08:29 PM
xxblindxx's Avatar
Maybe check altenator? does it crank a tiny bit then stop?
VolvoLisa
Mar 22, 2005 01:48 AM
bigb1rd
Mar 1, 2005 09:59 AM
bccb037
Dec 29, 2004 04:42 PM
rl92821
Feb 1, 2004 12:54 PM
