StylinMotors Inc. turbo hoses for ETM models, Finally here
Old May 19, 2006 | 08:44 PM
S70driver's Avatar
Default StylinMotors Inc. turbo hoses for ETM models, Finally here
So my turbo hoses are finally here.
Old May 19, 2006 | 08:50 PM
Default RE: StylinMotors Inc. turbo hoses for ETM models, Finally here
COOL pics pics pics??????
Old May 19, 2006 | 09:16 PM
S70driver's Avatar
If your not a member of Volvospeed you may not be able to view it.
Old May 19, 2006 | 09:20 PM
Then post it here.
Sorry Not a member.
Old May 20, 2006 | 02:49 AM
S70driver's Avatar
There is the picture for you all.
Yes it is a big picture. Don't mind the text. The two on the left are the lower IC connections, then next one is the upper IC connection and the fourth one is correct and goes on the Upper IC pipe in the back near the turbo.
Old May 20, 2006 | 10:12 AM
Looks good thanks for posting the Pics.
Old May 20, 2006 | 12:29 PM
S70driver's Avatar
ORIGINAL: tech
No problem.
My one turbo hose has a rip/tear in it, so I have to send it back. I got two of the four hoses on today. The other one that I have to put on is the lower IC elbow bend one.
The one I have to send back is the upper IC one that goes from the intercooler to the black plastic tube.
Old May 20, 2006 | 12:31 PM
Damb that sucks about the one hose!!!
Hopefully they will get a new one back to you fast.
Old May 20, 2006 | 12:43 PM
S70driver's Avatar
Called and surprisingly someone was there and talked to them. Should be sending one out to me on Monday.
Old May 20, 2006 | 02:20 PM
Cool
Old May 20, 2006 | 05:07 PM
S70driver's Avatar
If you guys with the ETM's are interested I would seriously order these turbo hoses. They are great!
Old May 20, 2006 | 05:36 PM
S70turbo1999's Avatar
im def doin it soon. today i might possibly order a 3 pod thingy, some not yellow side turn lights, and the vacuum hoses from styling hoses.
Old May 20, 2006 | 05:53 PM
S70driver's Avatar
Get the triple gauge pod from http://www.gaugepods.com
Old May 20, 2006 | 06:23 PM
ORIGINAL: S70driver
They only carry a 1 guage Pod for my Stang.(They suck)
They carry a 3 Pod for the Probe (YUCK)
Old May 20, 2006 | 06:58 PM
S70driver's Avatar
They carry a nice selection for Volvo. Single which is the same one IPD sells but Lotek (Gauge Pods sells it for $15 less). Lotek also sells a triple system as well. Oh by the way IPD now sells a triple pod as well, however theirs are like $20 more then Lotek's.
Get the LOTEK, please.
Fitment is good too.
Old May 20, 2006 | 07:07 PM
LOL like I said they don't sell the 3 Pods for my Mustang.
Old May 20, 2006 | 07:39 PM
  #17
S70driver's Avatar
Well I am sure someone else does.
Old May 20, 2006 | 07:41 PM
  #18
i need a cheap a/f gauge but didnt see ne on gaugepod.com
Old May 20, 2006 | 07:42 PM
  #19
S70driver's Avatar
I got my Lower IC turbo hose the one that goes to the intercooler on the bottom just about 30 minutes ago.
I bought some Rhino Ramps, woah are they better then jackstands. Car goes up in the air higher and the ramps can hold like 12,000 pounds. Good investment if I do say so myself.
Also to make it easier on yourself when you install the hose take the bottom hose clamp off the 90* hose that is above and pull the whole bottom assembly out it is just the bottom black metal pipe and the rubber hose that connects to that pipe and the intercooler on the bottom. Then remove the rubber hose and put the silicone version on then put it back in the way you took it out.
Remember guys this is for the cars with ETM I am talking about so anything before 1999 will be different, since I don't know what they look like.
Old May 20, 2006 | 07:44 PM
  #20
S70driver's Avatar
ORIGINAL: S70turbo1999
Sent you a PM
