ticking when cold
Old Feb 27, 2008 | 08:53 PM
bc's Avatar
bc
Default ticking when cold
I am looking at getting an S70 from a mechanic friend as a work exchange. When I start the car, it has what I would describe as "lifter noise" if it were on another vehicle. It goes away when it warms up. He said it is the cam follower. The car has 156,000 and is very clean otherwise.
Any thoughts? I wouldn't buy the vehicle if I were simply purchasing given the motor noise, but this is a way to get paid on what he owes me. Thanks in advance for any comments
Old Feb 28, 2008 | 08:21 AM
JimKW's Avatar
Default RE: ticking when cold
How is the oil level? Some of these cars do have ticking lifters while other are fairly quiet. My last one had a tendency to tick when it was even slight low on oil. My white one ticks pretty loud while the other two are pretty quiet, but it runs great most of the time.
Old Feb 28, 2008 | 06:12 PM
Most likely it has bad oil pan o-rings I made a post about replacing them.
Old Feb 29, 2008 | 08:31 AM
Paulie's Avatar
I found an interesting motor flush technique on another forum the other day. just google "2twisty flush" and check it out. basically you flush the motor with atf and a little oil, then drop and replace with motor oil. Sounds kinda ghetto, and I haven't tried it yet, but it's on my list of stuff to do. I'd be curious to see how it works.
Old Feb 29, 2008 | 11:52 AM
JimKW's Avatar
We've seen that on here before and most of us agree that we would NEVER try something like that on our Volvo's.
Old Mar 5, 2008 | 09:46 PM
roadrunvvo's Avatar
You may also want to check the oil dipstick o-ring. It's located between the oil pan and the dipstick holder. It's pretty common (according to the dealer) for it to warp and go bad. The oil usually seeps out while driving. You have to look real hard if you're just idling. The shop I went to had me up on the lift pressing the gas, while the tech saw the oil seeping out. If your oil seems to be disappearing, this may be the answer.
Captain Zov
Jun 18, 2021 12:01 PM
Chrispy_T
Oct 15, 2014 02:35 PM
Dennis Bor
May 30, 2011 11:14 AM
arttu
Feb 15, 2007 10:16 PM
Ocotillo
Mar 29, 2005 09:14 PM
