Timing belt/water pump packages
"Volvo Timing Belt Kit and Water Pump Kit (Comprehensive) OEM Parts - TBKIT252WP" ($299) - is this the package to get? I know how important the timing belt is, and I have had a pulley fail before, and I know that the water pump is logical to also do at this time. Do I need all the other parts replaced too? My 98 T5 is just shy of 140k.
I got a quote for $250 for the timing belt and water pump. I have a feeling it's going to go up when I show up with the rest of these parts ... The kit contains the following items: 271985 (30650751) Hepu German OEM Water Pump $144.89 272327 OEM Continental Timing Belt $52.74 - Includes spacer 9146693 OEM Aisin Timing Belt Tensioner List $165.07 9146376 GMB Timing Belt Idler Pulley List $103.17 9135036 OEM INA Timing Belt Tensioner Pulley List $110.05 Elring Front Crank Seal 6842273 List $15.47 Elring Front Cam Seal 6842272 List $15.99 Elring Front Balance Shaft Seal 6842272 List $15.99 Elring Rear Cam Seal 9443310 List $14.32 Elring Rear Balance Shaft Seal 9443310 List $14.32 Elring Rear Crank Seal 9458178 List $26.65 Continental Serpentine Belt 9186352 List $56.86 |
Wow 250 is really cheap. I got my lowest quote here of 400 with me supplying parts. I changed both belts in 7 hours. I would have been done it faster but my crank moved. So I took the crank pulley off and painted the block and pulley marks.
PS my conti timing belt with hydraulic button was $39.15 with shipping from eeuroparts.com You can get a kit from IPDusa.com Timing Belt Kit for manual $140 Timing Belt Kit for hydraulic $230 Water Pump Kit (Hepu) $64.59 Hepu So shop around. All the pulleys can fail, a pain. You lose a belt you rebuild the engine. I caught mine just in time. It had broken fibers in the core and had stretched about 1/2 a pulley tooth between the intake and exhaust pulleys. The engine is so smooth now compared to before it is like a new car. My turbo seems to come in faster. 169000 no leaks and no pulleys changed yet, and only the cam to distributor seal has been changed. |
