Timing belt/water pump packages
Old Jun 21, 2011 | 10:19 PM
yoyoman's Avatar
Default Timing belt/water pump packages
"Volvo Timing Belt Kit and Water Pump Kit (Comprehensive) OEM Parts - TBKIT252WP" ($299) - is this the package to get? I know how important the timing belt is, and I have had a pulley fail before, and I know that the water pump is logical to also do at this time. Do I need all the other parts replaced too? My 98 T5 is just shy of 140k.
I got a quote for $250 for the timing belt and water pump. I have a feeling it's going to go up when I show up with the rest of these parts ...
The kit contains the following items:
271985 (30650751) Hepu German OEM Water Pump $144.89
272327 OEM Continental Timing Belt $52.74 - Includes spacer
9146693 OEM Aisin Timing Belt Tensioner List $165.07
9146376 GMB Timing Belt Idler Pulley List $103.17
9135036 OEM INA Timing Belt Tensioner Pulley List $110.05
Elring Front Crank Seal 6842273 List $15.47
Elring Front Cam Seal 6842272 List $15.99
Elring Front Balance Shaft Seal 6842272 List $15.99
Elring Rear Cam Seal 9443310 List $14.32
Elring Rear Balance Shaft Seal 9443310 List $14.32
Elring Rear Crank Seal 9458178 List $26.65
Continental Serpentine Belt 9186352 List $56.86
Old Jun 23, 2011 | 04:28 PM
HeadDragon's Avatar
Wow 250 is really cheap. I got my lowest quote here of 400 with me supplying parts. I changed both belts in 7 hours. I would have been done it faster but my crank moved. So I took the crank pulley off and painted the block and pulley marks.
PS my conti timing belt with hydraulic button was $39.15 with shipping from eeuroparts.com
You can get a kit from IPDusa.com
Timing Belt Kit for manual $140
Timing Belt Kit for hydraulic $230
Water Pump Kit (Hepu) $64.59 Hepu
So shop around.
All the pulleys can fail, a pain. You lose a belt you rebuild the engine. I caught mine just in time. It had broken fibers in the core and had stretched about 1/2 a pulley tooth between the intake and exhaust pulleys. The engine is so smooth now compared to before it is like a new car. My turbo seems to come in faster. 169000 no leaks and no pulleys changed yet, and only the cam to distributor seal has been changed.
majorcode
Nov 4, 2013 06:41 PM
motosickle
Mar 24, 2012 05:31 PM
Ian L
Aug 12, 2009 10:11 PM
zeeman
Mar 1, 2008 06:16 PM
ramp
Nov 26, 2007 08:16 PM
