Transmission normal RPM speeds
Old Apr 20, 2012 | 05:11 PM
AZvolvoMan's Avatar
Question Transmission normal RPM speeds
To make it concise, i have a S70 base auto, when traveling close to 70mpg on highway, my RPMs are close to 3k. I am just afraid to travel faster with this car at about 75-85. is that normaol rpm speeds on these cars? Another question, when i am about to come to a stop, the RPM's bounce from 1.5k to 800 rpm's..
thnx
Old Apr 20, 2012 | 05:29 PM
@ 70 mph in our GLT the rpm's are around 2,200. Are you sure you are in D?
Old Apr 20, 2012 | 08:21 PM
kennedy759's Avatar
Is the tranny going into lock up, when mine is cold it takes awhile for it to lock up the torque converter and the rpm`s are high.
Old Apr 20, 2012 | 09:41 PM
I think "lock up" means that the tranny stays in it's gear as you slow down a bit. Example, my tranny usually shifts into 3rd at around 37 mph then into 4th at 54 mph. But if I slow down to 45 mph it will stay in 4th. It locks into 4th unless I slow down to something like 40 or hit the gas causing it to "kick-down".
I don't remember what they call it when the car downshifts when you're going down a steep hill. Sometimes when I'm going 60 mph and going down a steep hill my car will downshift by itself and then shift back into 4th when I put my foot in the gas pedal.
Old Apr 20, 2012 | 10:09 PM
Lifesgoodhere's Avatar
2450 RPM at 70 MPH in mine. GLT SE.
Old Apr 23, 2012 | 03:21 PM
AZvolvoMan's Avatar
Wow thanks for your replies and suggestions, i think im a replace/ flush the the transmission oil & filter to see what happends. Ill have to do a fuel filter, spark plug, cap & rotor replacement and even clean the throttle body. Any suggestions on tranny oil?
Old Apr 23, 2012 | 05:48 PM
short or long tranny dipstick?
yyk
Feb 4, 2013 03:58 PM
blwnkl
Apr 6, 2011 11:20 AM
seattlego
Jun 24, 2009 02:23 PM
lwrdr2
Dec 30, 2008 01:21 AM
