transmission problem. PLEASE HELP???
Old Dec 19, 2009 | 12:04 AM
gus_guerrero86's Avatar
Default transmission problem. PLEASE HELP???
I have a 1998 s70 t5 that iam having problems with. reverse gear gets stuck when i push the throttle, for example when i get in the car and press the gas to reverse the car takes off as if i were slamming on the gas, even when i have the brakes slammed. it feels as if the throttle cable gets stuck but the other gears work fine. need help asap. thanks
Old Dec 19, 2009 | 09:14 PM
s70_t5_1999's Avatar
is the Check engine light on or the flashing arrow?
Old Dec 19, 2009 | 11:51 PM
check engine light "is" on but problem started before the light came on (the light is on because of another issue but im taking care of it). ive asked a couple of people about it and they have said that they've never heard of something like this. so im hopeing someone here can help.
Old Dec 20, 2009 | 07:49 AM
Carrots's Avatar
are you saying that the car takes off quickly, or that reverse engages really hard? Like, does the car move really fast after it slams into reverse, or does it just feel like a hard "hit" when you first put it in reverse?
Old Dec 20, 2009 | 11:57 PM
well when i have to reverse from some where i put it on reverse, but theres no "hit", and i let it roll without pressing the gas, because as soon as i give it gas it will take off. i hope this is understandable.
Old Jan 3, 2010 | 11:08 AM
Mtl_Volvo_Man's Avatar
Sounds like a PNP switch
Rock the shifter back and forth a few times and try it
May need to be replaced
MNWILD
Sep 10, 2020 11:29 AM
BlackOut850
Aug 2, 2009 06:12 PM
hohoho43
Mar 20, 2008 11:51 AM
unit03
May 7, 2007 09:12 PM
fwchiro
Jul 16, 2006 03:57 PM
