Volvo S70 99 Misfire Issue
Old Feb 11, 2016 | 09:51 AM
Ben_25's Avatar
Default Volvo S70 99 Misfire Issue
I have a 99 S70 and I decided to change the spark plugs w/o changing the coils and one coil managed to go out in the process causing a misfire on cylinder #1. Yesterday I changed all 5 coils and the misfire is still present in cylinder 1 just not as bad. Do I need to change the plugs again? Could they have gone bad since they had to work harder? 143,000 miles on the car.
Old Feb 11, 2016 | 10:04 AM
check the gaps on the plugs, also check the connector to the coil in question - look for cracks/corrosion in the wiring itself. If you are getting a specific code, ie P0301, try swapping the coil for #1 with a coil from say #3... If you still get an 0301, its not the coil - so consider replacing the plug or the connector.
Old Feb 11, 2016 | 10:16 AM
Ben_25's Avatar
The gaps don't need adjustment since they're Bosch as noted on Amazon before purchasing. I asked some people and they said it's probably the plugs. They probably fouled out after driving around with the misfire for 2-3 days.
Old Feb 11, 2016 | 05:57 PM
while the plugs do ship pre-gapped, I still check since they can be off - I believe the '99s use .028 for NAs and .03 for turbos. I'd be curious to what you find - ie cracked insulator, blackened tip, a loose or soft connection to the plug cap etc.
Old Feb 15, 2016 | 12:25 PM
Ben_25's Avatar
Funny story. We took out the 6 day old spark plug and it cracked clean in half. Put in a brand new one and BAM. Problem fixed.
Old Feb 15, 2016 | 06:22 PM
$2.49 and you're back in business. thanks for the update.
hours
Dec 24, 2014 08:51 AM
ConkersBadBreath
Dec 7, 2014 11:22 AM
xxblindxx
Jul 3, 2010 06:17 PM
chevolvo
Feb 28, 2009 11:43 AM
