Volvo S70 run rough at idle
Old Mar 3, 2010 | 09:50 PM
volvos701999's Avatar
Default Volvo S70 run rough at idle
My 1999 volvo s70 runs rough at idle when I am stopped at a light. It feels like a misfire or hiccup but not all the time. The check engine light is not on. The first mechanic did a complete tuneup and changed 1 ignition coil. It got a little better but did not completely fix the problem. I went back and they changed another coil -- this still did not fix the problem. Does anyone have an idea of what the problem is? Do I need to replace all the coils? Is it hard to replace them? A friend asked me if there is a distributor cap on a volvo that my be cracked?
Old Mar 6, 2010 | 11:09 AM
spaded09's Avatar
Clean your maf and throtle body maybe it will get better.
Old Mar 9, 2010 | 04:05 PM
brasstacks's Avatar
Default rough idle
I am experiencing a simular problem. idle bounces about three notches on the rev counter every 2 - 3 secs. let me know if you find a fix for this problem
thans Phil
Old Mar 10, 2010 | 07:02 AM
Bad coils should pop a cel. My guess would be a vacuum leak somewhere. Check around the idle valve first.
nkinkade
Feb 28, 2014 08:49 PM
rosesforlily
Nov 5, 2009 09:23 AM
yank50
Mar 14, 2009 11:15 AM
Townleyba
Jun 25, 2008 09:26 PM
