WHEEL ALIGNMENT
Old Nov 27, 2007 | 02:28 PM
chachouu's Avatar
Banned
Default WHEEL ALIGNMENT
Besides tires what are the other Symptoms,of a bad alignment or no wheel alignment at all,for some reason my car doesn,t feel real stable,when I swirve sometimes the car feels like it will roll over.
s70 non turbo
new OEM strust and assembly part
new tires
new sway bar links
Old Nov 27, 2007 | 04:03 PM
Eric J's Avatar
Default RE: WHEEL ALIGNMENT
Sounds like a sway bar link is broken.
Old Nov 27, 2007 | 05:38 PM
JimKW's Avatar
Feeling like it's going to roll over has nothing to do with alignment. Pulling and uneven tire wear are the major indications of alignment problems. Something wrong with the suspension if it feels like it's going to roll over.
Old Nov 28, 2007 | 06:59 AM
chachouu's Avatar
Banned
I have almost new sway bar link,4 months old from FCPGROTON
Old Nov 28, 2007 | 10:24 AM
Eric J's Avatar
Recheck them to make sure an end didn't pop off. I'd jack it up and check the front thouroghly. If it checks out OK, Make sure you don't have a manatee on the roof,LOL.
Old Nov 28, 2007 | 04:36 PM
samadkins29's Avatar
I was gonna say what JimKW said, it sounds like a suspension issue.
Put your sterring wheel straight while going say 20MPH, let go, the car should keep going straight, if not then its not aligned.
For the problem you feel when turning, its not the aligment, when I had my power steering rack repalced I ahd to drive from the shop to firestone with it badly miss aligned, but at no point did I feel un-safe while takinga turn. I just had to turn by feel rather than looking at teh postion of the steering wheel.
Old Nov 28, 2007 | 04:58 PM
S70_Driver's Avatar
Without driving the car it's hard to understand exactly what the symptoms are... but at least from what I understand, it sounds like your car has low roll resistance on hard turns.
Roll resistance will be given by shocks/struts, springs, and anti-roll (anti-sway) bars -all 3 of these factor in.Assuming that there is no defective part, I will say that the stock parts, especially on the standard S70, aren't especially stiff - the rates are chosen more for the comfort end of the spectrum.
Mystandard S70corners very flat, but it has higher-rate IPD sway bars riding inharder polyurethane bushings that come with them, plus higher-rate Koni Sport shocks and struts. With this setup, it handles more like an "R" model would. It's not cheap to set the car up this way, but if you like it and plan to keep it, and want crisp handling, it's well worth it in my opinion. Including installation, expect about $1200+ for this kind of alteration.
bestharry
Aug 16, 2008 11:16 AM
bluemagicbus
Jun 13, 2008 06:54 PM
caspi
Apr 27, 2008 02:55 PM
atornquist
Apr 1, 2008 01:42 PM
jdbs3
Jun 26, 2006 09:33 PM
