01 S80 engine noise
Old Jan 17, 2009 | 06:20 PM
Dingdingmao's Avatar
Default 01 S80 engine noise
I just had my 01 volvo got maintenance by a volvo dealer. But a high pitch noise comes out from the engine area when I just switch the key from 0 to 2. I did not hear this kind of noise before I sent my volvo to the dealer today.
When I returned to the dealer check
toout what is going on, the machinists said it is normal for 01 s80 and nothing wrong with it. I highly doubt it. Could some one give me some suggestion? Thanks a lot!!!
The noise is uploaded as attachment. please change the file name "noise.JPG" to "noise.WAV" before open it.
Old Jan 17, 2009 | 07:36 PM
JTapper's Avatar
Default RE: 01 S80 engine noise
no luck downloading it. Does it come on, and run for about 2 seconds or so? Mine did that from new until it was wrecked at 96k miles.....
Old Jan 17, 2009 | 08:07 PM
Thanks for your reply.
Please try this one. I attach it again.
Old Jan 17, 2009 | 08:10 PM
Still nothing.
Maybe it is the injectors making like a tapping noise? If so that is normal.
Old Jan 17, 2009 | 08:30 PM
Thanks.
Before I did the 120,000 KM maintance today, it has no such noise. But after the maintance, the noise comes. The maintance included following items:
1 1275810 8 FILLTER INSERT
1 977751 7 GASKET
7 OIL CASTROL GTX
1 30630752 1 POLLEN FILTER.
Therefore, is it possible that dealer's job cause this problem?
Old Jan 17, 2009 | 08:32 PM
I doubt it unless the oil level is low.
Old Jan 17, 2009 | 08:35 PM
BTW. it souds like continuing high pitch chime
Old Jan 17, 2009 | 08:37 PM
The engine oil is changed today when they did mantance. And I checked it, it is full.
Old Jan 17, 2009 | 08:40 PM
The attachment is recorded when the engine is NOT started, but is powered. (Switch the key from 0 to 2 directly.)
Old Jan 17, 2009 | 09:15 PM
If the car is not running then what you might be hearing is the electronic throttle unit.(which is normal)
Old Jan 17, 2009 | 09:50 PM
Thanks.
I don't know it is the electronic throttle noise, fuel pump noise or gas filter noise. Because when the engine is powered (not start), these parts are working.
Old Jan 17, 2009 | 09:59 PM
The fuel pump only runs for a second or 2 then stops.
The ETM stays powered and will make like a humming noise.
Old Jan 17, 2009 | 10:18 PM
Thanks, Tech.
The noise continues 10 seconds (NOT humming). Then the engine power is down automaticly.
Could you please tell your email, I can send you the noise file?
Old Jan 17, 2009 | 10:21 PM
I will send you a PM with my e-mail.
Old Jan 17, 2009 | 10:26 PM
The noise is like the water jug whistle.
Old Jan 17, 2009 | 10:34 PM
Did you get my PM?
If so e-mail the noise to me.
Old Jan 17, 2009 | 10:35 PM
  #17
Thanks Tech. I sent you the noise file.
Old Jan 17, 2009 | 10:36 PM
  #18
That is the electronic throttle body. Yes it is normal for that to make noise. Not sure why you never heard it before but they all do that.
Old Jan 17, 2009 | 10:39 PM
  #19
Hi Tech,
Great, great, great thanks.
BTW, does this noise happened on a new car?
Old Jan 17, 2009 | 10:54 PM
  #20
The NEW NEW cars have a little bit of a different setup.
But it happens on the 99-I think it is 2003 on S70,V70,S60,S80's.
In I believe late 2003 for the 2004 model they changed the throttle body to a really small one.
