01 s80 t6 upgrade
I have 2001 Volvo s80 t6 looking add power just not sure what way go with it yet looking see any good tips and what not to start with? Thank you going be my 1st post so go slow now..
I plain on doing a ipd ecu flash that being 1st
with the t6 fwd you should have more than enough power.... enough to get you in trouble and burn up plenty of tires.... I would do a tune up... check the turbos and especially the waist gates and do all maintenance that you can you will likely find many factors leading to power loss especially on these cars
If you are at 100% you could do the ecu upgrade.... high flow cats and a cat back of your choice
ok thats something ill look in to im going replace all coils and maybe even both turbos the driver side one makes lot of clicking sounds not to sure what thats about seems to have boot problems also.
started last night |
Originally Posted by jbb240
(Post 429127)
thats not to bad i got do pvc and mounts thinking go with ipd strut mount solid and poly bushing for uper engine mount.
I under stand ill get more feed back but thats fine also all belts and what not are new and my miss is random some times car will run good then at red light rpm will just drop to like 500 then back to the 700s again? was told it maybe ummm brain fart but the etm i think need be cleaned |
(Post 429145)
also do yourself a big favor do a once over on all suspension components... especially if anything is clunking... also pull off the rear discs to take a look at the ebrake... if it looks iffy replace it... mine randomly caught and sheered off the cable and a piece of the hub... in my church parking lot of all places
yeah im going do all coils think they are the 1 set with 150k on them and all mounts new brakes and clean of the etm and intake with rebuild for turbos see where i sit from there i have a srs light on i think going get the software for volvo with cable do that my self
(Post 429156)
my one set off by new battery put in so think its just how it was put in bugged it out "Volvo makes some $$ reset it to" needless to say nothing bad.
was looking at Vdiag Dice Vida Volvo Vida Dice Diagnostic Tool 2014D Newest Version | eBay plugs in to laptop and change all kinda stuff able look at 02 and all that good stuff |
(Post 429159)
will do met guy at car show who use it and he said its just right to turn off stuff and reset far as re mapping stuff he say no but for easy stuff its got it down.
for 150$ if i can reset that light it pays for its self since Volvo wants 150$ just tell me why its on |
