05 s80 squealing / high-frequency squeaking
Old Jan 17, 2011 | 05:45 PM
dtrigiani's Avatar
Default 05 s80 squealing / high-frequency squeaking
resolved, thanks for that tip on the exhaust.
Old Jan 27, 2011 | 06:56 AM
AndySlv's Avatar
Small leak in the exhaust? Maybe the exhaust has a slightly loose hanger causing it to shake, chirp, or rattle as you go, speed just causing more vibrations.
Just a guess or something to look for, hopefully you have a shop or garage, -20 is a bit cold to just grab the creeper and take a look underneath ^^
Old Jan 27, 2011 | 10:11 AM
Volvo_n00b's Avatar
Quick fix that could save you a grand later.. might possibly be the idler pulley. The bearings wear out and chirp as they rub against each other. If it breaks on the freeway it will take the s belt and timing belt w it. Also such high mileage may need to do the timing too but definitely consider the tensioner and idler pulleys.
roadtrippers
Jan 31, 2017 12:27 PM
M363P
Sep 30, 2011 08:15 AM
s40sedan
Jun 14, 2011 05:14 AM
JDusza
Mar 11, 2011 11:43 AM
