1999 volvo s80
Old Nov 17, 2011 | 07:14 AM
jakbnimble2's Avatar
Exclamation 1999 volvo s80
Alternator problems? Dash board lights up and is flashing all icons like a neon sign, a/c wouldn't work properly, panel lights flash bright, then dim, fan runs high, finally I'm left "dead in the water." Bought it used, and seller had put in a "new" alternator. I installed new battery week prior. Towing service suggested bad alternator/voltage regulator. Can you help?
Old Nov 20, 2011 | 03:47 PM
hughrhodes's Avatar
Sounds like a faulty ABS module. When you have a bad ABS module on a 99 Volvo, it will make your dash completely fail to include tac and speedo and also lights up every warning light. The car will still run BTW. You can usually reset it by disconnecting the battery for a minute but it will eventually happen again and more often. Need to be repaired. ModuleMaster | Volvo Processor Also, watch the Youtube video Volvo S80 ABS module for step by step guide to remove.
darkostoj
Aug 1, 2018 08:27 AM
rezology
Jun 13, 2010 10:42 PM
7antera
Jun 2, 2008 08:00 AM
HelgaTheS80
Nov 18, 2006 05:53 PM
P4rD0nM3
Oct 11, 2006 07:15 PM
