2000 s80 2.9 engine trouble
Old Jul 2, 2009 | 02:21 PM
hbombhondacrew's Avatar
Default 2000 s80 2.9 engine trouble
i think that my timing belt has slipped, its struggles sometimes on start, and today when i tryed to pass on the highway my check engine light started flashing, i got off the highway and i pulled the codes 430D, 4308, 3503, 3513, 644A,
evap leak, some other stuff i didnt know, and crank shaft unaligned so im guessing its the timing belt, should i just get a new one and bring it all to TDC?
Old Jul 3, 2009 | 09:21 AM
any ideas????? or does anyone know what all the codes stand for?????
Old Jul 3, 2009 | 09:31 AM
If the check engine light was flashing that is usually misfire issues like plugs or coils.
Old Jul 3, 2009 | 09:32 AM
robretpd's Avatar
I have no clue what the codes are but my 1999 has had the ABS module go bad and the throttle body go bad. If it is the throttle body, you may be covered under a ten year warranty. I am not all that knowledgeable on codes etc...but it seems that both of these two problems can play havoc on the computer system.
Old Jul 5, 2009 | 03:18 PM
i pulled the plugs and i think that the number 1 cylinder was not firing correctly, and the other plugs looked to be burning too hot idk thinking about replacing the coil probably check the resistance of them first to see ifs its burnt out or something
Dkennedy
Jul 17, 2013 08:13 AM
Palaur
Mar 8, 2013 06:23 PM
briand1
May 2, 2009 12:55 PM
olddaddy
Mar 17, 2009 07:33 PM
foker500
Aug 3, 2007 09:53 AM
