2000 S80 2.9 Evap Code (Check Engine)
Old Sep 24, 2011 | 04:22 PM
ionracing's Avatar
Question 2000 S80 2.9 Evap Code (Check Engine)
We keep getting the check engine light. I have replaced the gas cap because the seal inside was cracked. It went off and now it is back on. I was told the next step is to see if the hose fell off the evap canister. Can someone tell me where the evap canister is. Also any other suggestions
Old Sep 24, 2011 | 07:36 PM
pan's Avatar
pan
It's located underneath close the gas tank, black square box with couple hoses attached . Check the hoses around the clamps see the the cracks, or you might need purge valve or shuttle valve.
Old Sep 27, 2011 | 08:46 PM
The Viper's Avatar
and is harder then heck to get to...to get to the cannister and the 9 inch "J" hose you will need to take off the right rear tire (standing from the front looking towards the back). I have big arms so i was able to get to the hose where it comes into the cannister just barely (it had cracks), getting to the other end of the hose is darn near impossible
Old Sep 28, 2011 | 09:12 AM
seefest's Avatar
I had my car on the lift ,the canister is dead center on top of rear suspension subframe I had the code,To replace J hose you would have to drop down-tilt subframe to replace hose,I was just barely able to get my finger in there with some silicone on it,let it set an hour, cleared the code did not come back.Sold car got tired of fixing things and then something else poping up,three years was enough!
thunderdan27
Jun 20, 2014 09:48 AM
chrisvolvo850r
1998-2000 model year V70
Jun 5, 2012 12:05 PM
Zamboni
Feb 7, 2011 01:15 PM
spunkymonky
Nov 18, 2008 08:41 PM
jmd
Mar 28, 2008 10:51 AM
