2000 s80 Antenna Ring not receiving power
Old May 12, 2014 | 11:42 PM
cabdoctor's Avatar
Default 2000 s80 not starting
My 2000 s80 is doing the typical failed antenna ring symptoms. I was able to get it to crank by shorting to ground the starter relay pin #85 while turning the key and bypassing the immobilizer(of course it didn't start because the injectors wouldn't fire). I pulled the antenna ring and swapped it with the one in my xc90 and the xc fired up just fine with what I expected to be the faulty ring. I put the antenna ring of the xc in the s80 and nothing. The radio, all the lights and accessories work. I tried shifting it into all gears thinking it was the PNP switch and that did nothing. Not sure what it could be.
Old May 13, 2014 | 01:43 AM
cabdoctor's Avatar
The antenna ring is getting power despite what my thread title says
Feb 14, 2025 11:49 AM
veritas1
Apr 8, 2013 10:12 PM
piv15
Nov 10, 2012 11:12 AM
alecw81
Jan 7, 2009 05:22 PM
leslieking20
Feb 24, 2008 04:05 PM
