2000 - S80 overheating
Old May 23, 2011 | 10:18 PM
brownbeltmama's Avatar
Default 2000 - S80 overheating
I have a 2000 S80 that keeps over-heating. I have had into the volvo dealership twice, and into firestone 3 times now. No one can find out what the problem is - even with 3 different diagnostic tests!
It is not a head gasket , nor is it the radiator, or thermostat. All of those have been checked.
I have also replaced the coolant tank and thought it might have a pin hole in the tank... this did not help.
I have to frequently put coolant in it - which leaks out - then the car over heats.
This has been happening for quite some time.
Has anyone else had this problem?
Thank you.
Old May 25, 2011 | 06:41 PM
tony1963's Avatar
Probably leaking heater hose, heater core or heater core o-rings. See if your driver's carpet is damp.
Old May 26, 2011 | 12:55 PM
NoLifeTilBoost's Avatar
Did you replace the cap ay the same time as the coolant tank?
trade in my volvo
Mar 13, 2015 05:35 PM
EisenhardtS80
Dec 20, 2013 11:04 PM
uwphoto48
Dec 23, 2012 02:51 PM
stella
Aug 5, 2009 09:33 PM
kroe
May 3, 2008 05:42 PM
