2000 Volvo S80 Door Lock
Old Nov 4, 2011 | 08:43 PM
trill2ride's Avatar
Default 2000 Volvo S80 Door Lock
Hey guys, I'm having a unique problem here.
The left rear door does not lock all the time. It only locks sometimes and sometimes I have to manually lock it. But, it has no problem unlocking. It unlocks every time I try to unlock it.
Did anyone ever experience this before?
Any input is much appreciated.
Thanks.
Old Nov 4, 2011 | 10:31 PM
SVolvoD4's Avatar
I actually had the same problem on my V70, I have just checked it everytime I get out which can be kind of annoying, but I got used to it. I haven't had the problem lately though. Just before it stopped, I replaced my fuses, so maybe the door lock fuse wasn't working well, but I don't know. It might also need to be lubricated or the CCM might need to be looked at. I was also thinking it could be the switch or the wiring to it considering it is just one door.
Old Nov 5, 2011 | 06:20 PM
mrybar's Avatar
power door lock actuator is the problem.. not sure if it's part of the latch or can be replaced seperately ?
Old Nov 7, 2011 | 04:24 PM
trill2ride's Avatar
Does anyone know the part number for the power door lock actuator? Also, if the power door lock actuator is the problem, isn't is suppose to not lock or unlock at all? My door unlocks all the time but only locks sometimes.
Old Nov 10, 2011 | 09:13 PM
trill2ride's Avatar
Come on guys I would really appreciate any thoughts on this.
Old Nov 10, 2011 | 10:17 PM
SVolvoD4's Avatar
It could be the actuator, I don't know the part number, but, take your door panel off and look at the part to see if there's the number on it. Also check your wiring to the actuator, that might be shorting. But like I said, try replacing the fuse... I would try the easiest options first, and if they don't work, probably need to get the actuator switch out.
Lgbpop
May 26, 2021 03:34 PM
ionracing
Oct 18, 2014 09:22 AM
qcvol
Jun 17, 2013 09:55 PM
crgolf
Feb 10, 2013 12:43 PM
rcvolvo
Jun 3, 2012 02:25 PM
