2004 s80 5 cylin 2.5 battery help
Old Nov 18, 2010 | 12:59 PM
twinvolvo's Avatar
Default 2004 s80 5 cylin 2.5 battery help
Hello
I'm glad I found this site. I'm new here. I believe I need a new battery the indicator light states low battery...any suggestions on where one would go to replace that won't cost an arm & a leg. Dealership with labor quoted $175
Suggestions would be helpful....also one last bit...I may need a new tining belt...help with this too
Thanks in advance for your help
Old Nov 18, 2010 | 03:06 PM
jlewisinsyr's Avatar
Sure it's the battery and not the alternator failing to charge the battery?
I think diagnostics are in order before jumping right to replacing what may at first appear to be the obvious. Replacing a battery is very simple though. Disconnect negative cable, disconnect positive cable, remove old battery, install new battery, connect positive cable, connect negative cable. The battery is in the trunk under the rear cover.
For a timing belt, I'd find a local trusted European mechanic (or even a Volvo specialist) and have them replace it. It won't be cheap no matter what, but what's worst is having one snap on you.
Cargirl2013
Jun 13, 2013 08:13 PM
ninayaa@sayclub.com
Jun 16, 2010 01:35 AM
mrcanon918
Sep 24, 2009 12:35 PM
cmercon
Feb 2, 2009 02:15 AM
fritzlovesmary
Jan 1, 2008 11:17 PM
