2006 Volvo s80 2.5t AWD questions
Old Jul 29, 2015 | 01:22 PM
nvantass90's Avatar
Unhappy 2006 Volvo s80 2.5t AWD questions
So I'm having some problems and any help would be greatly appreciated. The first start of the day or starting after a few hours of it being shut off the car takes 2-3 extra cranks and then starts up but when it starts it sends a slight jolt that i feel through the steering wheel and pedals. Its never not started and it does this no matter the weather. The plugs and boots were just done in February, maf has been cleaned, injectors cleaned and fuel filter replaced.
Second issue just started last month. I replaced my upper engine mount and my strut bar bushings to the ipd poly. The cabin vibration was terrible and i started to notice at low gears when my rpms were at 1500 there is a vibration in the acceleration pedal, someone on facebook told me to check my lower engine mounts I got them checked and they are fine. So i replaced the ipd stuff with OEM parts and now the cabin vibration is gone but the vibration at lower gears is still there. Anything before or after 1500rpm is smooth, its just 1500rpm.
The only part on the car i need to replace is the inner tie rods. Im just not sure if that would cause the vibration. Thanks in advance!
Phil 850
Jul 25, 2012 10:01 PM
robretpd
Feb 12, 2012 06:20 PM
mikesmith20001
Oct 1, 2009 08:52 AM
robretpd
Mar 17, 2009 09:27 PM
dcecchino
Jan 4, 2007 10:49 AM
