2008 S80 T6 Power Steering Cooling Coil Connector
Does anyone know where I can find the plastic quick disconnect that attached the cooling coil to the reservoir on a 2008 S80 T6? I've called Volvo and looked at a couple websites and all I can find is the whole line. I don't want to buy the whole line just for that one little connector.
Its item 5 in this picture https://www.volvopartswebstore.com/i.../GR-391978.jpg
not likely that you will find the components within a part like that. I suppose you can ask a shop that specializes in hydraulics to see if they can repair your unit or you can shop used via a yard. Best price I saw for PN 3139150 was $290 so I can appreciate your interest in not replacing the part just for a fitting.
I just checked the size for my 2010 S80 and it seems to be 3/8”
based on on that I think this will work
https://www.dormanproducts.com/p-490...origin=keyword
note it may be more like this one
https://www.summitracing.com/parts/r...waAplXEALw_wcB
you will need to measure the reservoir and hose to get the correct size
Let us know if this works and which part number is correct
thanks
Paul
thanks
Paul
a2wolverine
06-14-2013 04:29 PM
