99 S80 Door Lock
Old Feb 21, 2011 | 06:21 PM
Gtownwes's Avatar
Default 99 S80 Door Lock
Need help with my 1999 S80. The key will not unlock the drivers side door. I don't think it's the actuator because the remote and the lock button from the inside works fine at locking/unlocking. It's just the key that does nothing! I don't get it? Any ideas?!
Old Feb 22, 2011 | 07:13 PM
beefheart's Avatar
what exactly does your key do when you insert it in the lock cylinder on the drivers door? does the key work on the passenger side door ?
Old Feb 25, 2011 | 08:35 PM
Gtownwes's Avatar
I can turn the key both ways freely, but nothing happens. I don't believe there is a key hole on the passenger side door.
Old Feb 26, 2011 | 02:24 PM
beefheart's Avatar
I would guess that if you remove the door panel you will find that the linkage that goes between the lock cylinder and the door latch is seperated, hope this helps.
Lgbpop
May 26, 2021 03:34 PM
qcvol
Jun 17, 2013 09:55 PM
crgolf
Feb 10, 2013 12:43 PM
rcvolvo
Jun 3, 2012 02:25 PM
Enzo
Feb 14, 2006 09:04 PM
