99 S80 T6 power flattens around 4500 rpm
Old Aug 24, 2011 | 01:33 PM
ADB's Avatar
ADB
Default 99 S80 T6 power flattens around 4500 rpm
Hi my 99 t6 accelerates very fast off the line and up to 4500-5000rpm, then it seems to flatten out is that normal? I thought the second turbo is supposed to work at higher rpm. I have new plugs and all cylinders are firing fine with no faulty codes.
Any suggestions?
Old Aug 25, 2011 | 12:23 PM
hcmandog's Avatar
Sounds like you're having the same problem I am. I just found out my catalytic converter came apart and ended up in my muffler. It got so hot it melted the inner fender wheel well. I would look to see how hot your muffler is. I had an issue with faulty o2 sensors, replaced them and no codes but flat line at 4500 rpm. Let me know what you find out.
Old Aug 31, 2011 | 11:28 PM
ADB's Avatar
ADB
[quote=hcmandog;286520]Sounds like you're having the same problem I am. I just found out my catalytic converter came apart and ended up in my muffler. It got so hot it melted the inner fender wheel well. I would look to see how hot your muffler is. I had an issue with faulty o2 sensors, replaced them and no codes but flat line at 4500 rpm. Let me know what you find out.[/qu
I am still trying to figure it out, It works well 80% of the time, it may be a old vaccuum hose.
Old Sep 4, 2011 | 04:15 PM
fernando s80 twinturbo's Avatar
i am also having that same issue with mine..it starts to loose boost at 4500
snowwillfall
Mar 30, 2014 10:22 PM
chromecarz00
Nov 6, 2013 05:25 PM
nicolaselias
Nov 19, 2011 10:19 AM
Joran
Jan 12, 2011 03:34 PM
ciao-rich
Jun 13, 2008 05:01 PM
