ac problem, Please help, its hot here!!!
I have a 2000 s80 t6 and the ac is not working. Its done this before. The compressor is kicking on and the dial shows that its turning on but there is no air blowing out at all. Could this be a relay?
RE: ac problem, Please help, its hot here!!!
It could be the relay or the fuse or the blower motor or the resistor or a connection. Check the fuse first, then the relay, then check the 12v to the blower.
Ive checked the fuses on the dr side dash and the engine bay ones but all seem fine. where is the relay and how would i chech it? Sorry, i cant find a manual anywhere. Thanx
Check to see if you have 12v going to the blower motor. It is behind the glove box.
ok, I pulled the orange plug from the blower motor and there is no juice coming to it. would that be the relay then? If so, where is that located and how would I test it? Thanx again.
So I get into the car this morning and the ac is working now. It has done this before too. It will just start working.
