ac problem, Please help, its hot here!!!
Old Jul 1, 2008 | 09:47 AM
kh0007's Avatar
Default ac problem, Please help, its hot here!!!
I have a 2000 s80 t6 and the ac is not working. Its done this before. The compressor is kicking on and the dial shows that its turning on but there is no air blowing out at all. Could this be a relay?
Old Jul 1, 2008 | 10:19 AM
Eric J's Avatar
Default RE: ac problem, Please help, its hot here!!!
It could be the relay or the fuse or the blower motor or the resistor or a connection. Check the fuse first, then the relay, then check the 12v to the blower.
Old Jul 1, 2008 | 10:30 AM
kh0007's Avatar
Ive checked the fuses on the dr side dash and the engine bay ones but all seem fine. where is the relay and how would i chech it? Sorry, i cant find a manual anywhere. Thanx
Old Jul 1, 2008 | 11:22 AM
Eric J's Avatar
Check to see if you have 12v going to the blower motor. It is behind the glove box.
Old Jul 1, 2008 | 01:01 PM
kh0007's Avatar
ok, I pulled the orange plug from the blower motor and there is no juice coming to it. would that be the relay then? If so, where is that located and how would I test it? Thanx again.
Old Jul 2, 2008 | 09:34 AM
kh0007's Avatar
So I get into the car this morning and the ac is working now. It has done this before too. It will just start working.
sleepdotcom
May 30, 2012 11:07 AM
04XC90T6AWD
May 16, 2011 06:08 AM
koster
Jul 27, 2010 12:31 PM
beardo265
Sep 27, 2007 09:24 AM
