Aftermarket radio 2002 s80
Old Aug 17, 2014 | 08:03 PM
jmoshkowski's Avatar
Default Aftermarket radio 2002 s80
Hello i just replaced the OEM Radio with an Aftermarket Unit. After doing so the SRS LIGHT Came on So now i need that cleared. My question is: Can i just have that cleared and be on my way or is there going to be a continued issue?
1. I have a bunch of wires that are not being used now. I just taped them off. Is that ok or does one of those wires need to be connected to clear the SRS light?
2. I also get a wine out of the unit now from the accelerator. I have to troubleshoot this but the car is away. Is it just a ground?
3. The only wires i have connected are Ground, Acc+, B+ and The speakers.
4. does anyone know where i can find a radio schematic?
Old Aug 17, 2014 | 09:44 PM
850R4Ever's Avatar
take a look below and see which wire you have laying around.
which Head Unit (HU) model number you had originally on your s80? SC 710 - SC 810 - SC 811 - SC 813 - SC 816 - SC 900? etc.
What model of aftermarket radio did you installed?
2002 Volvo S80 Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: N/A
Car Radio Accessory Switched 12v+ Wire: N/A
Car Radio Ground Wire: N/A
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): N/A
Left Front Speaker Negative Wire (-): N/A
Right Front Speaker Positive Wire (+): N/A
Right Front Speaker Negative Wire (-): N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): N/A
Left Rear Speaker Negative Wire (-): N/A
Right Rear Speaker Positive Wire (+): N/A
Right Rear Speaker Negative Wire (-): N/A
Old Aug 18, 2014 | 02:46 PM
Default Wire color
Thanks for the reply i found that schematic it is more or less useless it doesnt have any wire colors on it. I will look into the radio unit model.
MarkD
Mar 20, 2015 12:32 PM
jollyrogermike
Jan 21, 2010 10:06 AM
J Crew
Oct 6, 2009 12:20 AM
brians46236
Feb 21, 2009 03:26 PM
