Another S80 Turbo Question
Old Jun 30, 2007 | 05:42 PM
drizzt05's Avatar
Default Another S80 Turbo Question
Are the turbos set up to spool sequentially or is it an equal-load set up?
Old Jun 30, 2007 | 10:22 PM
S70driver's Avatar
Default RE: Another S80 Turbo Question
I do believe they spool up sequentially.
Old Jul 1, 2007 | 08:14 AM
drizzt05's Avatar
So is there going to be a bit of a problem using two turbos of bigger size?
Old Jul 1, 2007 | 08:26 AM
S70driver's Avatar
ORIGINAL: drizzt05
I don't know. I mean I would suggest them being the same size turbos and everything else.
Old Jul 1, 2007 | 09:23 AM
JAKESTERS's Avatar
Turbos WHY ?I would only put two turbos on a v6 or v8. Since there is only one exhaust manfold on 5cyl volvo. why would you put two turbos on it ? Get a t3-t4 garret. If you go too big it would take like 3500 rpm for it to spool up. The turbos would have to be lined up to get equal pressure from the exhaust. You would have to do alot of piping . Not worth it, get one good turbo watercooled. For instance i have a t-4 on a ford 2.3l merkur xr4ti and it took 3000 rpmfor it to spool up after gutting exhaust 3' manderal bent down pipeand porting ,i have it back down to 2500 rpm. 23 bar. And dry 50 shot of NOS.
Old Jul 1, 2007 | 09:49 AM
ORIGINAL: JAKESTERS
Just so you know this car has an inline 6 cylinder with 2 exhaust manifolds and 2 turbo's already.
Old Jul 1, 2007 | 10:06 AM
JAKESTERS's Avatar
K
Old Jul 1, 2007 | 10:22 AM
S70driver's Avatar
That is why it is called a s80T6.
Twin Turbo six cylinder.
dnarby
Nov 7, 2013 11:08 PM
donf
Jul 4, 2012 08:47 PM
96960Chris
Jun 25, 2011 04:49 PM
Svenn
Jun 1, 2010 01:27 PM
HelgaTheS80
Suspension
Mar 16, 2007 04:23 AM
