Anyone know where the ac relay is and how to check it?
Old Jul 1, 2008 | 09:40 PM
kh0007's Avatar
Default Anyone know where the ac relay is and how to check it?
Ac is not blowing air but compressor is kicking on. No volts at the blower. Thanx for any help.
Old Jul 2, 2008 | 05:27 PM
Default RE: Anyone know where the ac relay is and how to check it?
Usually either the blower motor or resistor is bad.
Old Jul 2, 2008 | 09:34 PM
kh0007's Avatar
I checked the plug in at the blower motor and there is no power coming to it. Ive checked all fuses but not sure whech resister is.
Old Jul 2, 2008 | 10:25 PM
The resistor is inside by the blower motor. You will have to remove the motor to check the resistor.
Old Jul 3, 2008 | 05:28 PM
kh0007's Avatar
Thanx, AC is working for the moment but just curious if everyone has the same issue with the air not blowing that hard. Seems like there should be alot more air pressure coming from the vents. Its been like this since I bought the car so Im not sure if its normal or not.
Old Jul 3, 2008 | 07:18 PM
Maybe the pollen filter is clogged not allowing alot of air to enter.
Old Jul 3, 2008 | 08:13 PM
kh0007's Avatar
Wow, okay, didnt realize there was a filter. Where is that located? Thanx again.
Old Jul 3, 2008 | 08:49 PM
It is under the dash on the passenger side. Remove the lower dash panel. Then look for a black panel the screws go straight up. They are torxes 25 screws. There is also 2 types of filters. If you have teh small one you can get away with only removing the 2 screws towards the seat and fold the cover down and work the filter out. If you have the bigger one you will need to remove the 4 screws and it will slide out. The front 2 screws are a pain to get to. They are close to the firewall.
Old Jul 4, 2008 | 07:02 PM
kh0007's Avatar
Ahhh, much better, The filter was piled with crap. Thank you for your assistants.
Old Jul 5, 2008 | 01:40 AM
fs's Avatar
fs
weird, I wonder if your filter was so plugged up it made the blower moter work overtime and get hot or something? Keep us posted if it keeps on keeping on without doing anything else.......
Old Jul 5, 2008 | 10:39 AM
Glad it is better now.
sleech
Jan 25, 2020 05:07 PM
zandrew
May 8, 2014 02:36 PM
Juleshart
Jan 2, 2011 10:41 PM
syclone50
Mar 3, 2009 02:21 AM
tech
Sep 7, 2008 01:37 PM
