Battery or Alternator?
Old Dec 20, 2010 | 05:54 PM
Westwood's Avatar
Default Battery or Alternator?
2001 Volvo S80 2.9 Non Turbo
For about six months now a message would pop on the dash "low battery voltage". It'd stay on for about a minute then go off. No big deal. It'd happen once out of every fifteen trips.
This weekend I took it to MA. About 20m from my house battery message came up. About 2m later a red light with a picture of a battery kicked on. Then ABS lights. Then I lost the speedo. Then it started downshifting. I lost my lights and I pulled over. I got it towed and now its at my parent's house in MA.
My Dad charged the battery and it started fine. It was idling for a bit no problems. Still said low battery voltage. He pulled it out of the driveway and everything died on him. We're pretty certain its the original battery and alternator. So does it sound like the battery is junk? Or is the alternator not keepng the battery charged? Can an alternator only work at 50% capacity and simply the car is using more power than the alternator is recharging at?
Old Dec 20, 2010 | 06:02 PM
jlewisinsyr's Avatar
There is a voltage regulator in an alternator and a failed regulator (or even alternator) can cause all sorts of voltage issues in the car from too much to too little.
I'd get the battery and alternator tested at a local auto parts store (ie. Autozone). Just take both out and bring them to the part store and ask for them to test them. Honestly, it sounds like the alternator is shot.
Old Dec 20, 2010 | 08:21 PM
Westwood's Avatar
Someone else mentioned that too. So the regulator is in alternator?
How big of a job is this? I am doing this on my own. Though, my expertise is lifted Jeeps and Samurais; little less wiring in a 50 horse carbureated 1300cc engine than my Volvo's, haha.
Old Dec 20, 2010 | 08:52 PM
The alternator is pretty easy to remove, you just need to remove the accesory belt, connector and a few bolts. The voltage regulator is a seperate part, but most likely you'll need to just replace your whole alternator.
cmercon
Feb 2, 2009 02:15 AM
MarkS90Atlanta
Jun 19, 2008 05:38 PM
axis72
Jan 21, 2008 08:45 AM
gfreeman9mm
Apr 30, 2007 01:28 AM
bhaven
Sep 7, 2005 09:24 PM
