89 240 Volvo battery low / alternator
Old Sep 7, 2005 | 09:01 PM
bhaven's Avatar
Default 89 240 Volvo battery low / alternator
The other night I noted that the head lights were dim and the instrument panel light very low. I measured the battery and it was around 12 volts with the car running. Shouldn't the voltage be around 14 volts with the car running due to the alternator charging the battery?
I also expected the battery voltage to increase and head lights to get brighter with and increase in engine RPMs. The voltage and the brightness of the head lights did not change with RPMs.
Is my alternator bad?
Old Sep 7, 2005 | 09:24 PM
Default RE: 89 240 Volvo battery low / alternator
That alt. could be going bad.Also does the battery light come on very dim?
The regulator/brushes could be worn and need to be replaced.Look on the back of the Alt.There is a peice that is held in with 2 phillips screws that is it.
shavalena
Jan 7, 2017 02:43 PM
imaitland
Oct 9, 2012 11:54 PM
MarksS60
Nov 30, 2010 04:52 PM
cmercon
Feb 2, 2009 02:15 AM
elderzap
Nov 7, 2007 04:58 PM
