brake failure....
Once again, I was reversing held down the brake, for 20 seconds or so, The ABS and STC light came on, and the message ABS System brake failure came up... I dont get this, fluid is fine, brakes are good - 12-15k miles of life left on them... What could this possibly be?
It is located on the bottom of the ABS setup. It is a black box with 2 plugs going to it.
You can have it rebuilt for about $150.00 or cheaper.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
Check out the link to learn a little more.
That is all tied to the ABS module.
Most of the time if there is a failure in the hydrolic system only the BRAKE light will come on like if you were low on fluid.
1.) interesting note, I slammed on breaks from 30mph-0(I wanted to really test it- Great stopping power), and it came on, does that change anything?
2.) Also, could the thumping of my 1000watt stereo cause problems, maybe the vibrations could be doing something? Is there anything in the trunk that could be doing?
3.) The wires that are tucked on the sides of the car, near the seats(on each side) are there any wires that i may have spliced into?......I highly doubt the tweeter company installers could have done that?
4.) Sometimes this ABS light and STC light come on at idle or during a slow breaking, or a hard breaking, its kinda intermittent........but sometimes not....Could possibly one of the brakes not be malfunctioning in the Clamping down or something?
On a side note sometimes I hear a Beeeeeeeep noise in the back area of the car....
ok, I hope i can get volvo to cover it under warranty....its gonna be tough, but maybe if i B**** enough ill get my way.....threaten with a Volvo headquarters call lol...
Im so not under warranty,
Since I bought the car used, I've been to Volvo on an average of twice per month,recently I have had to pay for stuff, but i'll see if I can get them too......hahaha when you use to work at volvo, did you have any tricks that you saw customers use?
turned out, they said the battery voltage was too low, and that it was charging intermittantly.....So they replaced the battery, for 107$, 72$ to pull the codes...
the codes they pulled was a 0074.
I must have been pulling to much power with my system hahah.. Interesting though the Brake, ABS, and STC trlights flicker on and off because of that..
cheebster
May 8, 2014 04:31 PM
rburner
Apr 19, 2011 09:14 AM
kosmoscanyon
Dec 16, 2008 12:39 PM
