cam alignment help
Old Sep 7, 2011 | 12:29 PM
volvoedmonton's Avatar
Default cam alignment help
i have a 99 S80 T6 with bent valves. I gave the head to a machine shop to clean and put new valves. now how do i time the intake and exhaust cam shafts. I have locked both shafts in place. But how do i align the cams step by step
Old Sep 8, 2011 | 11:08 PM
samss80's Avatar
I am a new member and I had the same issue with my S80 2.9. After searching the forum for days, I was able to find all the answers. I will try share my experience with you.
First of all, I would like to thank everybody in the forum who posted extremly valuble information.
You do not need to purchase any special tools! However, you will need a tool to lock the cam VVT unit is attached to. I used the following link to create a simple tool:
https://volvoforums.com/forum/genera...ication-38396/
There is a slot at the other end of each camshaft. The slot on the intake shaft should be horizontal- above an imaginary center line, and the slot on the other cam should horizontal - below an imaginary center line. This may vary depending on the engine, but one should be up and the other down with respect to a center horizontal line.
Be sure to lock the cams, especiallly the one VVT unit is attached to.
Align the marks and install the belt.
You must set the VVT timing!!!! I found the following article extremly helpful:
https://volvoforums.com/forum/volvo-...osition-49525/
I didn't set the VVT timing thinking that all should be fine if I put everything back as before. I could not start the car. There was no compression in any of the cylinders. Then I realized that the VVT rotated one of the cams without disturbing the timing marks. I was extremly lucky as it could have bent some of the valves.
There are some software you can purchase on ebay that has most of the steps.
Hope this helps!
m3rd
Jun 24, 2017 05:00 PM
ToyoLoyal
Nov 19, 2010 08:24 PM
seanmathes
Feb 6, 2010 09:12 PM
cncinc
May 31, 2009 04:25 PM
Osmenthe
Jul 9, 2005 01:36 PM
