Car doesn’t start as no fuel reach engine!!
![Question](https://volvoforums.com/forum/images/icons/icon5.gif)
Hi guys,
My car S80 2007 doesn’t start as no fuel reach engine!!
Problem happened one month ago, I changed the fuel pressure sensor and fuel pump.
Again, same problem happened 4 days ago (3 weeks after replacing the fuel pressure sensor and Fuel Pump).
I noticed that, no signal comes to the fuel pump and once the engine starts the car is running perfect!!
Finding; when I press the brake pad and push start bottom, no electrical signal come to the fuel pump!!
Action I did:
- I removed the fuel tank and check the fuel pump separately it’s ok! And wire all is OK!!
- I passed the pump electronic module through a hole under the back seat and kept the module under the seat for easy access if it needs to change.
- Car starts immediately with no problem and runs perfectly even the acceleration is ok (why not the problem was engine start only)
- I put into the tank “Fuel system cleaner fluid” to clean injectors and remove any clogs.
Conclusion;
1- When I press the brake pad, no electrical signal is delivered, or
2- On starting the car PEM sometimes delivers signal to Pump and sometimes doesn’t deliver signal to pump.
Question:
1- Do I need to replace the PEM or
2- Is the problem with the wire coming from the brake to PEM or
3- Another mechanical issue?
I highly appreciate your valuable advice.
Action I did:
Conclusion;
Question:
